REW update
Hi Pete,
if the 2.404 applikation is showing when you check the system-data, then you have updated your REW to the newest stage. That part is finished!
The gracenote now has to be updated.
Go to the Swiss server load down the gracenote update files onto your computer, entpack these data-packages (2059 and 4621) and then put the entpacked file 2059 in a folder and the 4621 file in a seperate folder.
I burned each file on a seperate Platinum DVD with expressburn at slowest speed (4x). With Nero I also had problems!
Just turn the key of your vehicle so that the radio would run. Insert the 2059 DVD into your REW. Data is shown shortly and then the question if you want to update. On a "Yes" the radio will tell you that it takes about 30 min to update, but in truth it took 2,5 hours on my REW unit. Don´t touch the radio after you´ve answered with "yes". Get out of the car, open the boot and just keep the car in sight. When everything is done the radio goes on again and askes you if you want to update. Say "no" and take the DVD out of the radio.
Switch the radio off and lock up the car for 10min.
Same procedure with gracenote update 4621.
Hope it works now!!!
Regards Cay
