Question on AWD system on 300C
1 reading
20K views 7 replies 5 participants last post by  daleafrancis
#1 ·
I have a 2007 300C with AWD.
My question is how does the awd system work on the 300?
Is is like the Jeep Grand Cherokee;Basically a rear wheel drive but if the rear wheels detect a slip the front wheels kick in
or is is like the audi that has all four wheels going continuously?
#3 ·
R U sure?
Because the previous vehicle I just came out of (04 Grand Cherokee) was a 4X4 with Quadra TracII
Basically, the rear axle (rear wheels) was driving unless skip was detected then up to 50% of the power can be transferred to the front wheels.
That was when I was in Hi range
in 4WD Lo, all four wheels were digging....Basically for off road
#5 ·
Gotcha....
Makes sense now
So is it safe to say my front wheels will only engage if they detect a slip from the rear wheels?
In a way, it Kind of defeats the purpose of traction control.
My jeep never had traction control I guess because it had Quadra trac II. So there really was no need for traction control...
#6 · (Edited)
The 300 AWD is basically the older Mercedes' 4Matic system. 62% of the engine’s torque goes to the rear wheels and 38% to the front, fixed, at all times. That way it keeps the rear drive handling feel. It's not considered very sophisticated, compared to Audi or Subaru set ups, but it's effective nonetheless. AWD is AWD: Floor the throttle in wet conditions and you get no wheel spin, just instant forward thrust. Stay into the throttle on turns way past sane speeds and the car simply hooks up. 2009 and up AWD models feature a front axle disconnect system that only spins the front axle when AWD is needed.
