body control module bcm location
68K views 24 replies 5 participants last post by  jackwalton
#1 ·
Hi there, have the dreaded no bus on instrument cluster, scanned with launch x431 loads of communication faults in all the low speed bus modules with no communication with instrument cluster, carried out self test on cluster all ok. trying to check wiring between cluster and bcm but can't find it anywhere! its probably staring right at me but would someone be so kind and tell me where
Many thanks
Don
#3 ·
I've never heard of the "dreaded no bus on instruments" on our cars
#5 ·
Thanks for the help guys should have said it is a crd. Checked the wiring simon but couldn't fault it, and to UK CHRYSLER it is definitely ' dreaded 'when you've been working on it for nearly 4 hours :). There is a fcm bolted to under bonnet fusebox jack and checked all fuses a couple of times, a feel I'm missing something simple, customer parked up one night next morning exterior lights are on permanently when started and instrument cluster has all lights on with no Rev counter no stereo or wipers. Any other problem areas for bus faults is very much appreciated
Thanks again
Don
#9 · (Edited)
Could well be a single module dragging the CAN BUS signal down. Well worth disconnecting the lighting module as suggested.
If the above doesn't fix it I think the only way would be to refer to diagram, disconnect modules from ECM one at a time until BUS signal returns, (BUS would be best checked with an oscilloscope but can be done with a DVM, or poss. just rechecking for error codes ?). As you appreciate though, really time consuming.
Hope the lighting module fixes it. It is know to fail and affect the BUS and affect starting.
Think could get a diagram of all modules on BUS and connections if you need one but would take a bit of digging out.
From what I recall, the CAN BUS connections read about 2.4V DC on a DVM on both the "High" and the "Low" to chassis. Obviously this is not a signal measurement, just a means of checking for obvious faults or shorts to chassis. But obviously to check this you need a wiring diagram anyway to find the connection/module details.
Good Luck.
Jack
#10 ·
Hi all again, simon I had high hopes this morning but guess what its still the same, tried disconnecting battery to reset lasts for about 5 secs then all lights back on. If someone is able too supply a wiring diagram i would be eternally grateful or even know I link to one.
Thanks for everyone's input so far
Don
#14 ·
Was gonna email you a Pdf manual but file is too big and will not send, Sorry.
I think you've got the relevant bits for now though.
If you struggle I may be able to extract the relevant bit but I havn't got the software for splitting the file. I feel sure I could do it if it becomes necessary but I don't like loading new Software on Computer unless its essential.
Jack
#15 ·
Hi jack do you have diagram with the instrument cluster in loads of ecu's with no coms with cluster and its the only ecu my diagnostic machine won't talk to. Fault codes I have are in pcm U110a lost comms with scm can c
Abs u0126 lost comms steering angle sensor
Airbag u0208 and u0209 lost comms with seat modules u0186 with audio amp u0212 with steering column control module u0155 with instrument panel
Bcm u1107 ecu in single wire mode u0019 low speed can communication bus u110a lost comms with scm can c
Wcm u0155 lost comms with instrument panel etc etc
Sorry for the long list just in case it springs something into place
Thanks
Don
#16 ·
Where are you located as I know someone with a diagnostic tool that will read your car....
#20 ·
Thought I'd better get back in touch and but and end to this problem, by disconnecting each ecu and the fact there was no comms traced fault to instrument cluster customer didn't want to buy new so sourced a second unit finally after nearly two weeks arrived today fitted and all OK. Hope this helps someone in future. Huge thanks to Jack and everyone else that helped
Don
#21 ·
just a thought .... I cured a regular fuse blowing that knocked out several instrument functions. The fuse related to the steering control module which had no bearing on the defunct systems....the solution was to disable the 'courtesy' headlamps coming on when the remote entry was activated on the fob.
Try gradually disabling optional functions in the EVIC & see if theres a cure
